跳转到主内容
Nikon Coolpix L18 LCD Screen Replacement
你所需要的
  1. Nikon Coolpix L18 LCD Screen Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the memory stick from the camera.
    • Remove the batteries from the camera.
  2. Nikon Coolpix L18 LCD Screen Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix L18 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
    • There is one screw hidden under the AV cover that also needs to be removed.
  3. Nikon Coolpix L18 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Pry the back cover from the left side of the camera. Remove the cover gently.
  4. Nikon Coolpix L18 LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 1,1
    • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
  5. Nikon Coolpix L18 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the tape on the right side of the LCD screen.
    • Gently lift the LCD screen from its base.
    • Don't tug on the screen because it is still connected to the motherboard.
    Be very careful not to touch the flash capacitor on far left when lifting the LCD!! It WILL shock you.
    Mark Fraylick - 回复
    Getting the LCD ribbon back "in" is my problem -- hints or suggestions?
    richardkujawa - 回复
    I can't get a feel for how the black clip holds the ribbon - insert the new one at an angle?
    richardkujawa - 回复
    I practiced a few times with the "bad screen" and managed to figure this out. Unfortunately I can't explain how I did it... if some other person can explain how to make the ribbon connection/clip re-install more predictable I think it'd help anyone else who tries the repair.
    richardkujawa - 回复
  6. Nikon Coolpix L18 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Lift the black latch connecting the LCD ribbon to the motherboard.
    • Gently pull the LCD ribbon out.
结论
8等其他人完成本指南。
Nonny
于10/11/10注册
219 声望
创作了2篇指南
团队
Cal Poly, Team 9-23, Regan Fall 2010 Cal Poly, Team 9-23, Regan Fall 2010 的会员
CPSU-REGAN-F10S9G23
4 名成员
创作了10篇指南
4条评论
Good work! Appreciate it.
Oasis World - 回复
I need a new LCD screen replacement. A link to buy a new one?
William Pullman - 回复
Where can I get a replacement LCD screen for a Nikon L18 camera?
I found one for my Nikon Coolpix L18 on eBay.
Mark Fraylick -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 7,058
