跳转到主内容
Nikon Coolpix E5700 Rear LCD Replacement
你所需要的
  1. Nikon Coolpix E5700 Rear LCD Replacement, Battery: 步骤 1 中的图像 1,2 Nikon Coolpix E5700 Rear LCD Replacement, Battery: 步骤 1 中的图像 2,2
    • Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
    • Open the battery door.
  2. Nikon Coolpix E5700 Rear LCD Replacement: 步骤 2 中的图像 1,1
    • Pull the battery out of the E5700.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
  3. Nikon Coolpix E5700 Rear LCD Replacement, Rear LCD: 步骤 3 中的图像 1,1
    • Remove two Phillips screws (3.4 mm) located on the left side of the screen.
  4. Nikon Coolpix E5700 Rear LCD Replacement: 步骤 4 中的图像 1,2 Nikon Coolpix E5700 Rear LCD Replacement: 步骤 4 中的图像 2,2
    • Remove two Phillips screws (3.4 mm) located on the right side of the screens.
  5. Nikon Coolpix E5700 Rear LCD Replacement: 步骤 5 中的图像 1,2 Nikon Coolpix E5700 Rear LCD Replacement: 步骤 5 中的图像 2,2
    • Remove back plastic monitor cover.
  6. Nikon Coolpix E5700 Rear LCD Replacement: 步骤 6 中的图像 1,1
    • Remove the Phillips screw on the top right side of the screen.
  7. Nikon Coolpix E5700 Rear LCD Replacement: 步骤 7 中的图像 1,1
    • Carefully unplug the grey bundle of wires in the white housing.
  8. Nikon Coolpix E5700 Rear LCD Replacement: 步骤 8 中的图像 1,1
    • Carefully unplug the small pink and wires in the grey housing.
  9. Nikon Coolpix E5700 Rear LCD Replacement: 步骤 9 中的图像 1,1
    • Remove the two Phillips screws on the left side of the screen.
  10. Nikon Coolpix E5700 Rear LCD Replacement: 步骤 10 中的图像 1,1
    • Remove the metal bar on the left side of the screen.
    • Remove the screen from the front plastic housing.
结论
另外一个人完成了本指南。
Kyle Sitton
于04/17/11注册
351 声望
创作了7篇指南
团队
Cal Poly, Team 24-58, Amido Spring 2011 Cal Poly, Team 24-58, Amido Spring 2011 的会员
CPSU-AMIDO-S11S24G58
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,373
