当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
Open the battery door.
Pull the battery out of the E5700.
It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
Turn to the bottom of the camera.
Remove the two Phillips screws located directly below the back monitor
Turn the camera to the side with the memory card slot and open the compartment for the CF card.
Remove the top two Phillips screws closest to the back panel.
Turn to the back of the camera.
Remove the top most Phillips screw on the back panel.
Turn to the last side of the back panel.
Remove the Phillips screw below the eyepiece.
Remove the Phillips screw located above the speaker.
Gently begin to remove the back panel.
Caution: There are two bundles of wires connecting the back panel to the camera. Be sure not to pull too hard and yank these out.
Now gently unplug the two wires at the bottom of the panel.
取消:我没有完成这个指南。
2等其他人完成本指南。
与6其他贡献者
于04/12/11注册
78 声望
创作了2篇指南
徽章: 8
+ 5更多徽章
CPSU-AMIDO-S11S24G58
4 名成员
创作了18篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 13
总计 1,964
