跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Nikon Coolpix E5700 Back Panel Replacement
你所需要的
  1. Nikon Coolpix E5700 Back Panel Replacement, Battery: 步骤 1 中的图像 1,2 Nikon Coolpix E5700 Back Panel Replacement, Battery: 步骤 1 中的图像 2,2
    • Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
    • Open the battery door.
  2. Nikon Coolpix E5700 Back Panel Replacement: 步骤 2 中的图像 1,1
    • Pull the battery out of the E5700.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
  3. Nikon Coolpix E5700 Back Panel Replacement, Back Panel: 步骤 3 中的图像 1,1
    • Turn to the bottom of the camera.
    • Remove the two Phillips screws located directly below the back monitor
  4. Nikon Coolpix E5700 Back Panel Replacement: 步骤 4 中的图像 1,2 Nikon Coolpix E5700 Back Panel Replacement: 步骤 4 中的图像 2,2
    • Turn the camera to the side with the memory card slot and open the compartment for the CF card.
    • Remove the top two Phillips screws closest to the back panel.
  5. Nikon Coolpix E5700 Back Panel Replacement: 步骤 5 中的图像 1,1
    • Turn to the back of the camera.
    • Remove the top most Phillips screw on the back panel.
  6. Nikon Coolpix E5700 Back Panel Replacement: 步骤 6 中的图像 1,1
    • Turn to the last side of the back panel.
    • Remove the Phillips screw below the eyepiece.
    • Remove the Phillips screw located above the speaker.
  7. Nikon Coolpix E5700 Back Panel Replacement: 步骤 7 中的图像 1,2 Nikon Coolpix E5700 Back Panel Replacement: 步骤 7 中的图像 2,2
    • Gently begin to remove the back panel.
    • Caution: There are two bundles of wires connecting the back panel to the camera. Be sure not to pull too hard and yank these out.
  8. Nikon Coolpix E5700 Back Panel Replacement: 步骤 8 中的图像 1,2 Nikon Coolpix E5700 Back Panel Replacement: 步骤 8 中的图像 2,2
    • Now gently unplug the two wires at the bottom of the panel.
结论
2等其他人完成本指南。
Raana
于04/12/11注册
78 声望
创作了2篇指南
团队
Cal Poly, Team 24-58, Amido Spring 2011 Cal Poly, Team 24-58, Amido Spring 2011 的会员
CPSU-AMIDO-S11S24G58
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,954
