简介
This guide shows how to replace the full lens assembly and housing on the Nikon Coolpix B700 camera. This can be done if the lens glass is cracked or the sensor is damaged.
你所需要的
Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
Use the Phillips screwdriver to remove the remaining five 5.55mm screws.
Remove the single 6mm screw.
Use the Phillips screwdriver to remove the four 6 mm screw that hold on the bracket housing.
9等其他人完成本指南。
2条评论
how to reset an objective error on B700 ? the lens is stopped in the middle of a hike
how to reset an objective error? the lens is stopped in the middle of a hike
