跳转到主内容
Nikon Coolpix B700 LCD Screen Replacement
你所需要的
  1. Nikon Coolpix B700 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,2 Nikon Coolpix B700 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 3.5mm screws at the top and bottom of the LCD Screen.
  2. Nikon Coolpix B700 LCD Screen Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix B700 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 3.5mm screws on both sides of the side of the screen.
  3. Nikon Coolpix B700 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Use to metal spudger to pry open the LCD cover. Then slide it down the length of the screen until the cover comes apart.
  4. Nikon Coolpix B700 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Use the pry tool and slide it under the black tab and lift up gently. Do this again for the other two ZIF tabs.
  5. Nikon Coolpix B700 LCD Screen Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    Desoldering Pump
    $3.99
    • Use the solder gun and desolder the yellow and blue wires.
  6. Nikon Coolpix B700 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Use the jimmy and slide it in between the LCD screen and lift out the LCD Screen.
结论
2等其他人完成本指南。
2指南评论
Hi, I like the first 6 steps, but what are the rest of the steps?
Kevin Kirkendall - 回复
My camera the screen go’s when outside and if it cold.
gsb1306 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 32
总计 2,893
