跳转到主内容
Nikon Coolpix B700 Button Assembly Replacement
你所需要的
  1. Nikon Coolpix B700 Button Assembly Replacement, Back Frame Assembly: 步骤 1 中的图像 1,1
    • Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
  2. Nikon Coolpix B700 Button Assembly Replacement: 步骤 2 中的图像 1,1
    • Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
  3. Nikon Coolpix B700 Button Assembly Replacement: 步骤 3 中的图像 1,2 Nikon Coolpix B700 Button Assembly Replacement: 步骤 3 中的图像 2,2
    • Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
    • Open the HDMI flap to remove a 5.5mm screw.
    • Don't forget to replace the hidden screw under the HDMI flap during reassembly.
  4. Nikon Coolpix B700 Button Assembly Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
  5. Nikon Coolpix B700 Button Assembly Replacement: 步骤 5 中的图像 1,3 Nikon Coolpix B700 Button Assembly Replacement: 步骤 5 中的图像 2,3 Nikon Coolpix B700 Button Assembly Replacement: 步骤 5 中的图像 3,3
    • Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
    • While twisting, pry apart the shell to split the camera in half.
  6. Nikon Coolpix B700 Button Assembly Replacement: 步骤 6 中的图像 1,1
    • Be careful not to damage the ribbons that connect the halves together.
  7. Nikon Coolpix B700 Button Assembly Replacement: 步骤 7 中的图像 1,2 Nikon Coolpix B700 Button Assembly Replacement: 步骤 7 中的图像 2,2
    • Place the pry tool under the black latch. Lift gently until the latch flips up.
    • Gently pull the ribbon away from the latch.
    • Be gentle when taking ribbons out and apart because they are fragile.
  8. Nikon Coolpix B700 Button Assembly Replacement, Button Assembly: 步骤 8 中的图像 1,1
    • Lift the corner under the power button up.
    • While at the same time pushing the selector knob back.
  9. Nikon Coolpix B700 Button Assembly Replacement: 步骤 9 中的图像 1,1
    • This should remove the entire assembly from the camera housing.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 11
总计 519
