当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
When reassembling, you must turn this wheel to the right until it clicks.
Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
Carefully pull the plate off of the face.
Using the metal spudger tool, pry the colored face from the camera body.
Avoid bending or scratching the front face.
Using your thumb, separate the top piece of plastic from the camera.
If this piece does not come loose easily, try using the nylon spudger.
Using tweezers from the precision tweezer set, carefully loosen the shutter button.
Atop the camera, there are two buttons. The shutter button should be the largest of the two.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
