跳转到主内容
Nikon Coolpix AW130 Shutter Button Replacement
你所需要的
  1. Nikon Coolpix AW130 Shutter Button Replacement, Battery: 步骤 1 中的图像 1,2 Nikon Coolpix AW130 Shutter Button Replacement, Battery: 步骤 1 中的图像 2,2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Shutter Button Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix AW130 Shutter Button Replacement: 步骤 2 中的图像 2,2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Shutter Button Replacement: 步骤 3 中的图像 1,1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Shutter Button Replacement: 步骤 4 中的图像 1,2 Nikon Coolpix AW130 Shutter Button Replacement: 步骤 4 中的图像 2,2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Shutter Button Replacement, Front Panel: 步骤 5 中的图像 1,2 Nikon Coolpix AW130 Shutter Button Replacement, Front Panel: 步骤 5 中的图像 2,2
    • Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
    • Carefully pull the plate off of the face.
  6. Nikon Coolpix AW130 Shutter Button Replacement: 步骤 6 中的图像 1,2 Nikon Coolpix AW130 Shutter Button Replacement: 步骤 6 中的图像 2,2
    • Using the metal spudger tool, pry the colored face from the camera body.
    • Avoid bending or scratching the front face.
  7. Nikon Coolpix AW130 Shutter Button Replacement, Shutter Button: 步骤 7 中的图像 1,2 Nikon Coolpix AW130 Shutter Button Replacement, Shutter Button: 步骤 7 中的图像 2,2
    • Using your thumb, separate the top piece of plastic from the camera.
    • If this piece does not come loose easily, try using the nylon spudger.
  8. Nikon Coolpix AW130 Shutter Button Replacement: 步骤 8 中的图像 1,3 Nikon Coolpix AW130 Shutter Button Replacement: 步骤 8 中的图像 2,3 Nikon Coolpix AW130 Shutter Button Replacement: 步骤 8 中的图像 3,3
    • Using tweezers from the precision tweezer set, carefully loosen the shutter button.
    • Atop the camera, there are two buttons. The shutter button should be the largest of the two.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 1,078
