跳转到主内容
Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement
你所需要的
  1. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Battery: 步骤 1 中的图像 1,2 Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Battery: 步骤 1 中的图像 2,2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: 步骤 2 中的图像 2,2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: 步骤 3 中的图像 1,1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: 步骤 4 中的图像 1,2 Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: 步骤 4 中的图像 2,2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Map/Wi-Fi/Action Buttons: 步骤 5 中的图像 1,3 Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Map/Wi-Fi/Action Buttons: 步骤 5 中的图像 2,3 Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Map/Wi-Fi/Action Buttons: 步骤 5 中的图像 3,3
    • Using the spudger, pry the plastic button face from the camera body.
    • The sharp edges of the spudger could cut you or pierce an exposed battery.
  6. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: 步骤 6 中的图像 1,1
    • Using tweezers from the precision tweezer set, remove the buttons from the larger plastic piece.
  7. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: 步骤 7 中的图像 1,1
    • Using tweezers from the precision tweezer set, remove the silicon backing from the buttons.
    • From there, the buttons should dislodge from their plastic casing.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 666
