跳转到主内容
Nikon Coolpix AW130 LCD Screen Replacement
你所需要的
  1. Nikon Coolpix AW130 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,2 Nikon Coolpix AW130 LCD Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 LCD Screen Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix AW130 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 LCD Screen Replacement: 步骤 4 中的图像 1,2 Nikon Coolpix AW130 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 LCD Screen Replacement, Back Panel: 步骤 5 中的图像 1,2 Nikon Coolpix AW130 LCD Screen Replacement, Back Panel: 步骤 5 中的图像 2,2
    • Using the T5 Torx screwdriver, remove all four 4mm screws.
  6. Nikon Coolpix AW130 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Using a Phillips #000 screwdriver, remove the single 3mm screw found inside the battery/charging compartment.
  7. Nikon Coolpix AW130 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Remove the upper cover (connected by glue) and unscrew the single Philips screw.
  8. Nikon Coolpix AW130 LCD Screen Replacement: 步骤 8 中的图像 1,2 Nikon Coolpix AW130 LCD Screen Replacement: 步骤 8 中的图像 2,2
    • Remove two Philips screws from the bottom cover, lift gently the cover and remove the single Philips screw under it.
  9. Nikon Coolpix AW130 LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Carefully remove the back cover from the camera body.
  10. Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: 步骤 10 中的图像 1,3 Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: 步骤 10 中的图像 2,3 Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: 步骤 10 中的图像 3,3
    • Using a Phillips #000 screwdriver, remove all 11, 4mm screws on the LCD screen cover.
    • Two screws are located on the right.
    • The remaining screws are hidden behind a connector ribbon on the left.
  11. Nikon Coolpix AW130 LCD Screen Replacement: 步骤 11 中的图像 1,2 Nikon Coolpix AW130 LCD Screen Replacement: 步骤 11 中的图像 2,2
    • Pull the LCD screen from the plastic frame after removing all of the screws.
  12. Nikon Coolpix AW130 LCD Screen Replacement: 步骤 12 中的图像 1,1
    在这个步骤中使用的工具:
    • Using a pair of tweezers from the precision tweezer set, carefully remove the screen from the metal frame.
    • Since the tweezers could shatter the screen, causing for broken glass, exercise extreme caution.
结论
8指南评论
Hi.
Where can you buy a replacement screen?
Ben - 回复
Hi.
my contact is josem6073@gmail.com
Thank you .
Jose Martins - 回复
Please add Torx T5 screwdriver at the tool needed, required at step 5
macreateur - 回复
Hi.
my contact is cpapacon@gmail.com
Thank you .
Costis Papaconstantinou - 回复
Hi.
my contact is Keithdurkan@gmail.com
Thank you .
Keith Durkan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 20
总计 3,482
