简介
Removing the front face is necessary if the colored plate is damaged. This process is also a prerequisite for various other repairs.
你所需要的
Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
Push the yellow battery/charger compartment tab up using your thumb nail.
This yellow tab spring broken, how I can repair
From where I can get this yellow tab, and how I can replace
Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
Carefully pull the plate off of the face.
ChK 2022_01_27: There is no need to remove the front panel in order to get to the main board. Skip this step.
Using the metal spudger tool, pry the colored face from the camera body.
I think this step is unnecessary, and it´s very hard to take off this metal plate without damage
6等其他人完成本指南。
