跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Removing the battery is a necessary prerequisite step in all Nikon Coolpix AW130 repairs. Failing to complete this step prior to replacing the LED screen or shutter button, for example, may result in electrical shock. No tools are required.
  1. Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left. When reassembling, you must turn this wheel to the right until it clicks.
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. You should feel the door begin to loosen. Carefully pull the hatch open. You should feel the door begin to loosen. Carefully pull the hatch open.
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  4. Push the yellow battery/charger compartment tab up using your thumb nail.
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  5. After pressing the yellow tab, the battery should loosen. Slowly pull the battery completely out.
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
结论
Lauren Stepp
于2016年01月29日注册
1,149 信誉积分
创作了8篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 6
过去的30天: 19
总计 1,262
