跳转到主内容
Nikon Coolpix AW130 Battery Door Replacement
你所需要的
  1. Nikon Coolpix AW130 Battery Door Replacement, Battery: 步骤 1 中的图像 1,2 Nikon Coolpix AW130 Battery Door Replacement, Battery: 步骤 1 中的图像 2,2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Battery Door Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix AW130 Battery Door Replacement: 步骤 2 中的图像 2,2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Battery Door Replacement: 步骤 3 中的图像 1,1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Battery Door Replacement: 步骤 4 中的图像 1,2 Nikon Coolpix AW130 Battery Door Replacement: 步骤 4 中的图像 2,2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Battery Door Replacement, Battery Door: 步骤 5 中的图像 1,2 Nikon Coolpix AW130 Battery Door Replacement, Battery Door: 步骤 5 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the 2, 4mm screws on the underside of the camera.
  6. Nikon Coolpix AW130 Battery Door Replacement: 步骤 6 中的图像 1,1
    • Using the metal spudger, carefully pry on the plastic plate.
    • The plastic plate should begin to loosen. Completely remove it from the camera body.
  7. Nikon Coolpix AW130 Battery Door Replacement: 步骤 7 中的图像 1,2 Nikon Coolpix AW130 Battery Door Replacement: 步骤 7 中的图像 2,2
    • Open the battery door. Near the hinge, a pair of screws should now be exposed.
    • Using a Phillips #00 screwdriver, remove the 2, 4mm screws.
  8. Nikon Coolpix AW130 Battery Door Replacement: 步骤 8 中的图像 1,1
    • Pull the battery door away from the camera body.
结论
另外一个人完成了本指南。
6条评论
Where can I purchase the battery cover?
Thanh Tran - 回复
Where can I buy the AW130 battery door?
Jose - 回复
I’m trying to replace the battery door. I removed the 2 bottom screws and loosened the plate as in Steps 5 and 6. How do I remove the plate without breaking it?
Jose - 回复
like jose I have removed the screws and loosened the plate but can’t figure out how to remove it. How do I get it out?
Marianne Chaffin Strickland - 回复
Need web site to order battery door?
Connie Mossor - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 27
总计 4,116
