跳转到主内容
Nikon Coolpix 995 Memory Card Replacement
  1. Nikon Coolpix 995 Memory Card Replacement, Memory Card: 步骤 1 中的图像 1,2 Nikon Coolpix 995 Memory Card Replacement, Memory Card: 步骤 1 中的图像 2,2
    • Set camera so the memory card compartment is facing you.
    • Place thumb under cover latch where it says "card", then gently lift straight upwards.
  2. Nikon Coolpix 995 Memory Card Replacement: 步骤 2 中的图像 1,1
    • -Pull the memory card with your thumb gently .
  3. Nikon Coolpix 995 Memory Card Replacement: 步骤 3 中的图像 1,2 Nikon Coolpix 995 Memory Card Replacement: 步骤 3 中的图像 2,2
    • Be sure your memory card is facing the right direction, then gently insert it into the memory card slot.
    • After you properly reinsert the memory card, place your thumb on the top of the cover and gently press down until you hear and feel the cover click back into the closed position.
结论
另外一个人完成了本指南。
Cory Layman
于10/04/11注册
89 声望
创作了3篇指南
团队
UW Stout, Team 1-5, Zhou Fall 2011 UW Stout, Team 1-5, Zhou Fall 2011 的会员
UWSTOUT-ZHOU-F11S1G5
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 2,267
