跳转到主内容
Nikon Coolpix 995 LCD Replacement
你所需要的
  1. Nikon Coolpix 995 LCD Replacement, LCD: 步骤 1 中的图像 1,2 Nikon Coolpix 995 LCD Replacement, LCD: 步骤 1 中的图像 2,2
    • Turn the lens/flash assembly 90 degrees, until you see the two Phillips #00 screws,
    • Remove the two screws with a Phillips #00 screwdriver.
    • Flip the flash so that you can access the remaining two screws. Remove these screws following the same method as before.
    • Refer to the second image to locate the second set of screws. The relevant screws are highlighted in red.
  2. Nikon Coolpix 995 LCD Replacement: 步骤 2 中的图像 1,1
    • Flip the camera up-side down.
    • Remove the two Phillips #00 screws located near the battery compartment.
  3. Nikon Coolpix 995 LCD Replacement: 步骤 3 中的图像 1,1
    • Open the memory card compartment cover.
    • You can now see four screws under the cover. Remove all four screws.
    • Refer to the image to locate the four screws. Make sure that you remove only the four screws identified in the image.
  4. Nikon Coolpix 995 LCD Replacement: 步骤 4 中的图像 1,2 Nikon Coolpix 995 LCD Replacement: 步骤 4 中的图像 2,2
    • Use your thumb to carefully lift the bottom side of the casing near the battery.
    • Pay attention to a cable located at the top of the assembly, as it is prone to breakage. Refer to the second image to locate the cable.
  5. Nikon Coolpix 995 LCD Replacement: 步骤 5 中的图像 1,1
    • Use a spudger to flip the tabs that hold the screen.
    • Refer to the image for more details. The tabs are circled in red.
  6. Nikon Coolpix 995 LCD Replacement: 步骤 6 中的图像 1,1
    • Carefully lift the LCD from the bottom. It should come out fairly easily.
结论
Cory Layman
于10/04/11注册
93 声望
创作了3篇指南
团队
UW Stout, Team 1-5, Zhou Fall 2011 UW Stout, Team 1-5, Zhou Fall 2011 的会员
UWSTOUT-ZHOU-F11S1G5
5 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 24
总计 2,766
