当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
The back cover will be disconnected from the camera
Be careful of metallic parts which are loose and will fall out.
Remove the two 2.5mm screws on the bottom of the left side, after having removed the back cover.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
