跳转到主内容
Nikon Coolpix 7900 Back Cover Replacement
你所需要的
  1. Nikon Coolpix 7900 Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the four 3.0mm screws on the bottom of the camera.
  2. Nikon Coolpix 7900 Back Cover Replacement: 步骤 2 中的图像 1,1
    • Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
  3. Nikon Coolpix 7900 Back Cover Replacement: 步骤 3 中的图像 1,1
    • Remove the two 3.0mm screws on the right side of the camera.
  4. Nikon Coolpix 7900 Back Cover Replacement: 步骤 4 中的图像 1,1
    • Carefully open the back cover. Take care as there are connectors still attached.
  5. Nikon Coolpix 7900 Back Cover Replacement: 步骤 5 中的图像 1,1
    • Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
  6. Nikon Coolpix 7900 Back Cover Replacement: 步骤 6 中的图像 1,1
    • Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
    • The back cover will be disconnected from the camera
结论
另外一个人完成了本指南。
Kaky Payne
于04/17/12注册
121 声望
创作了5篇指南
团队
Cal Poly, Team 12-38, Regan Spring 2012 Cal Poly, Team 12-38, Regan Spring 2012 的会员
CPSU-REGAN-S12S12G38
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 1,324
