跳转到主内容
Nikon Coolpix 5400 Battery Door Replacement
你所需要的
  1. Nikon Coolpix 5400 Battery Door Replacement, Battery Door: 步骤 1 中的图像 1,1
    • Remove one 3mm Phillips #0 screw from the top of the camera back cover.
  2. Nikon Coolpix 5400 Battery Door Replacement: 步骤 2 中的图像 1,1
    • Remove three 3mm Phillips #0 screws from the side of the back cover.
  3. Nikon Coolpix 5400 Battery Door Replacement: 步骤 3 中的图像 1,1
    • Lift memory card flap.
    • Remove one 3mm Phillips #0 screw from the side of the back case.
  4. Nikon Coolpix 5400 Battery Door Replacement: 步骤 4 中的图像 1,1
    • Remove four 3mm Phillips #0 screws from the bottom of the back case.
  5. Nikon Coolpix 5400 Battery Door Replacement: 步骤 5 中的图像 1,2 Nikon Coolpix 5400 Battery Door Replacement: 步骤 5 中的图像 2,2
    • Use a plastic opening tool to gently pop the back case away from the body of the camera.
    • Pull the back case away from the camera very gently.
    • The connecting cables are very fragile and easily broken.
  6. Nikon Coolpix 5400 Battery Door Replacement: 步骤 6 中的图像 1,1
    • Flip camera over so the bottom is facing up.
    • Push the sliding latch to open the battery door.
    • Push the press fit pin firmly with a flat-head screwdriver to release it from the hinge housing.
    • Push to the left, half the length of the pin.
  7. Nikon Coolpix 5400 Battery Door Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Grasp the press fit pin firmly with precision tweezers to pull it from the housing.
    • Do not to drop the pin into the camera body.
  8. Nikon Coolpix 5400 Battery Door Replacement: 步骤 8 中的图像 1,1
    • Remove the battery door by lifting it out of the camera body.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 11
总计 245
