跳转到主内容
Nikon Coolpix 5400 Back Cover Replacement
你所需要的
  1. Nikon Coolpix 5400 Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove one 3.0mm Phillips #0 screw from the top of the case.
  2. Nikon Coolpix 5400 Back Cover Replacement: 步骤 2 中的图像 1,1
    • Remove two 3.0mm Phillips #0 screws from the card reader side of the case.
  3. Nikon Coolpix 5400 Back Cover Replacement: 步骤 3 中的图像 1,1
    • Remove four 3.0mm Phillips #0 screws from the bottom of the camera.
  4. Nikon Coolpix 5400 Back Cover Replacement: 步骤 4 中的图像 1,1
    • Remove one 3.0mm Phillips #0 screw from the side of the camera.
  5. Nikon Coolpix 5400 Back Cover Replacement: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to gently remove the back case from the rest of the camera.
  6. Nikon Coolpix 5400 Back Cover Replacement: 步骤 6 中的图像 1,1
    • Pull the back of the camera cover apart.
    • Connecting wires that are still attached to the back cover are fragile.
  7. Nikon Coolpix 5400 Back Cover Replacement: 步骤 7 中的图像 1,2 Nikon Coolpix 5400 Back Cover Replacement: 步骤 7 中的图像 2,2
    • Remove the two 4.0mm Phillips #0 screws holding the circuit board to the back case.
  8. Nikon Coolpix 5400 Back Cover Replacement: 步骤 8 中的图像 1,1
    • Pull the LCD screen cables in the direction that the wires are exiting the circuit board.
    • Pull the wire connector gently, the plastic is very fragile.
  9. Nikon Coolpix 5400 Back Cover Replacement: 步骤 9 中的图像 1,2 Nikon Coolpix 5400 Back Cover Replacement: 步骤 9 中的图像 2,2
    • Pull the toggle wheel wire connector up and away from the top of the camera.
    • Pull the button control panel wire connector up and away from the top of the camera.
    • Gently remove the wire connectors; the plastic is fragile.
  10. Nikon Coolpix 5400 Back Cover Replacement: 步骤 10 中的图像 1,1
    • Remove the six 3.0mm Phillips #0 screws holding the button control panel.
    • Remove the back cover from the camera body.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 358
