跳转到主内容
加入维修社区 - 创建账户
Nikon Coolpix 4600 LCD screen Replacement
你所需要的
  1. Nikon Coolpix 4600 LCD screen Replacement, Front and Rear Case: 步骤 1 中的图像 1,2 Nikon Coolpix 4600 LCD screen Replacement, Front and Rear Case: 步骤 1 中的图像 2,2
    • Locate the six screws on the exterior of the camera. There will be two 3.3 mm screws on the bottom and two 5.25 mm screws either side.
    • Using a Phillips 00 screwdriver, remove all of the six screws.
  2. Nikon Coolpix 4600 LCD screen Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix 4600 LCD screen Replacement: 步骤 2 中的图像 2,2
    • Gently separate the front and back casing by prying the two sides open with your hands. DO NOT separate them fully, as it could damage internal components.
    • The front case is attached to internal components and cannot be removed independently
  3. Nikon Coolpix 4600 LCD screen Replacement: 步骤 3 中的图像 1,1
    • Examine the connection between the ribbon cable and the motherboard closely. Identify the two grey tabs on each side of the connecting bracket.
    • Slide the grey tabs toward the bottom of the camera to release the ribbon cable. Gently disconnect the ribbon cable from the motherboard.
    • Once the ribbon cable is disconnected, you can now carefully separate the back case from the front case.
  4. Nikon Coolpix 4600 LCD screen Replacement, LCD screen: 步骤 4 中的图像 1,1
    • With the lens facing down and the bottom of the camera facing away from you, lift up the right edge of the LCD screen (left side of the screen will be glued down).
    • Be careful not to push the front case too hard on the table when taking the LCD out or the lens will get stuck.
    • Insert plastic tool under the screen and gently pry up the left side of the screen until the glue seal is broken.
  5. Nikon Coolpix 4600 LCD screen Replacement: 步骤 5 中的图像 1,1
    • Locate the orange ribbon cable and two wires (red and white) attached to the motherboard.
    • Lift up on the black clamp and pull out data cable.
    • Desolder the wires from motherboard. CAUTION: Improper desoldering can result in motherboard damage. Seek help if you do not have the necessary skills.
    • The screen should now be completely free from the camera.
结论
3等其他人完成本指南。
Nathan Sperling
于05/08/12注册
119 声望
创作了4篇指南
团队
Cal Poly, Team 9-43, Regan Spring 2012 Cal Poly, Team 9-43, Regan Spring 2012 的会员
CPSU-REGAN-S12S9G43
5 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 32
总计 1,552
