跳转到主内容
Nikon Coolpix 3500 Front Cover Replacement.
你所需要的
  1. Nikon Coolpix 3500 Front Cover Replacement., Battery: 步骤 1 中的图像 1,1
    • Unlatch the battery cover and slide the cover out. Place cover to the side, it will not be needed for the next few steps.
    • Remove the battery.
    • Remove the battery cover without using excessive force. Keep in mind this cover is fragile.
  2. Nikon Coolpix 3500 Front Cover Replacement., Front Cover: 步骤 2 中的图像 1,1
    • Remove the two 4.5 mm screws that sit next to the battery slot.
    • Remove the 3 mm screw that sits below the CF card slot.
    • Remove the 4.5 mm screw that sits above the digital I/O cover.
  3. Nikon Coolpix 3500 Front Cover Replacement.: 步骤 3 中的图像 1,1
    • Remove the two 4.5 mm screws that sit inside the battery slot.
  4. Nikon Coolpix 3500 Front Cover Replacement.: 步骤 4 中的图像 1,1
    • Remove the two 5 mm screws that sit near the camera strap eyelet.
    • Remove the camera strap eyelet.
  5. Nikon Coolpix 3500 Front Cover Replacement.: 步骤 5 中的图像 1,1
    • Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
  6. Nikon Coolpix 3500 Front Cover Replacement.: 步骤 6 中的图像 1,2 Nikon Coolpix 3500 Front Cover Replacement.: 步骤 6 中的图像 2,2
    • Remove the five 3.5 mm screws that sit at the bottom of the camera.
    • Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
    • Do not apply too much force; two wires still connect the front cover to the motherboard.
  7. Nikon Coolpix 3500 Front Cover Replacement.: 步骤 7 中的图像 1,2 Nikon Coolpix 3500 Front Cover Replacement.: 步骤 7 中的图像 2,2
    • Using a spudger, detach the white-capped wire.
    • Using a spudger, detach the orange-capped wire and set the front cover aside.
结论
richard guenther
于04/19/10注册
183 声望
创作了6篇指南
团队
Cal Poly, Team 30-38, Garner Spring 2010 Cal Poly, Team 30-38, Garner Spring 2010 的会员
CPSU-GARNER-S10S30G38
5 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 1,899
