简介
Replacing the front cover of a Nikon Coolpix 3500.
配件
无需配件。
  1. Unlatch the battery cover. Slide the cover out and flip it open.
    • Unlatch the battery cover. Slide the cover out and flip it open.
    • Remove the battery.
    • Gently remove the battery cover.
  2. Remove the two 4.5 mm screws that sit next to the battery slot.
    • Remove the two 4.5 mm screws that sit next to the battery slot.
    • Remove the 3 mm screw that sits below the CF card slot.
    • Remove the 4.5 mm screw that sits above the digital I/O cover.
    • Remove the two 4.5 mm screws that sit inside the battery slot.
    • Remove the two 5 mm screws that sit near the camera strap eyelet.
    • Remove the camera strap eyelet.
    • Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
    • Remove the five 3.5 mm screws that sit at the bottom of the camera.
    • Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
    • Do not apply too much force; two wires still connect the front cover to the logic board.
    • Using a spudger, detach the white-capped wire.
    • Using a spudger, detach the orange-capped wire and set the front cover aside.
结论
richard guenther
于2010年04月19日注册
183 信誉积分
创作了6篇指南
团队
Cal Poly, Team 30-38, Garner Spring 2010 Cal Poly, Team 30-38, Garner Spring 2010 的会员
CPSU-GARNER-S10S30G38
5 名成员
创作了6篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,692
