跳转到主内容
修复你的物品
维修的权力
商店
简介
Replacing the logic board of a Nikon Coolpix 3500
配件
没有特定配件。
  1. Unlatch the battery cover. Slide the cover out and flip it open.
    • Unlatch the battery cover. Slide the cover out and flip it open.
    • Remove the battery.
    • Gently remove the battery cover.
  2. Remove the two 4.5 mm screws that sit next to the battery slot.
    • Remove the two 4.5 mm screws that sit next to the battery slot.
    • Remove the 3 mm screw that sits below the CF card slot.
    • Remove the 4.5 mm screw that sits above the digital I/O cover.
  3. Remove the two 4.5 mm screws that sit inside the battery slot.
    • Remove the two 4.5 mm screws that sit inside the battery slot.
  4. Remove the two 5 mm screws that sit near the camera strap eyelet.
    • Remove the two 5 mm screws that sit near the camera strap eyelet.
    • Remove the camera strap eyelet.
  5. Essential 工具包
    我们最紧凑的套装中最有用的工具。
    现在开始购物
    Essential 工具包
    我们最紧凑的套装中最有用的工具。
    现在开始购物
  6. Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
    • Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
  7. Remove the five 3.5 mm screws that sit at the bottom of the camera. Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
    • Remove the five 3.5 mm screws that sit at the bottom of the camera.
    • Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
    • Do not apply too much force; two wires still connect the front cover to the motherboard.
  8. Using a spudger, detach the white-capped wire. Using a spudger, detach the orange-capped wire and set the front cover aside.
    • Using a spudger, detach the white-capped wire.
    • Using a spudger, detach the orange-capped wire and set the front cover aside.
  9. Detach the grey-capped wire.
    • Detach the grey-capped wire.
    • Detach the green chip that sits next to the blue wires.
  10. Remove the 3.5 mm screw that sits next to the rotating lens. Invert the logic board and lens to uncover the orange and blue ribbon cables. These cables still connect the logic board to the LCD screen.
    • Remove the 3.5 mm screw that sits next to the rotating lens.
    • Invert the logic board and lens to uncover the orange and blue ribbon cables. These cables still connect the logic board to the LCD screen.
  11. Detach the blue ribbon cable. Detach the orange ribbon cable by using a spudger, and while pushing it out horizontally.
    • Detach the blue ribbon cable.
    • Detach the orange ribbon cable by using a spudger, and while pushing it out horizontally.
    • Detach the red-capped wire.
    • Lift the logic board and lens, which are still connected, out of the back cover.
  12. Lift the black covering and remove the orange ribbon cable, which connects the lens to the logic board.
    • Lift the black covering and remove the orange ribbon cable, which connects the lens to the logic board.
结论
richard guenther
于2010年04月19日注册
183 信誉积分
创作了6篇指南
团队
Cal Poly, Team 30-38, Garner Spring 2010 Cal Poly, Team 30-38, Garner Spring 2010 的会员
CPSU-GARNER-S10S30G38
5 名成员
创作了11篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 1,916
