当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Unlatch the battery cover and slide the cover out. Place cover to the side, it will not be needed for the next few steps.
Remove the battery.
Remove the battery cover without using excessive force. Keep in mind this cover is fragile.
Remove the two 4.5 mm screws that sit next to the battery slot.
Remove the 3 mm screw that sits below the CF card slot.
Remove the 4.5 mm screw that sits above the digital I/O cover.
Remove the five 3.5 mm screws that sit at the bottom of the camera.
Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
Do not apply too much force; two wires still connect the front cover to the motherboard.
Using a spudger, detach the white-capped wire.
Using a spudger, detach the orange-capped wire and set the front cover aside.
Disconnect the blue wire connecting the motherboard to the LED screen.
Disconnect the orange wire using a spudger while pushing out horizontally.
Disconnect the red capped wire from the motherboard.
Lift the motherboard and lens (still connected) out of the back case.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
