本指南有最近更改,您可查看未经巡查的最新版本。
简介
Replacing the front cover of a Nikon Coolpix 3500.
你所需要的
Unlatch the battery cover and slide the cover out. Place cover to the side, it will not be needed for the next few steps.
Remove the battery.
Remove the battery cover without using excessive force. Keep in mind this cover is fragile.
Remove the two 4.5 mm screws that sit next to the battery slot.
Remove the 3 mm screw that sits below the CF card slot.
Remove the 4.5 mm screw that sits above the digital I/O cover.
即将完成!
结论
