跳转到主内容
Nikon CoolPix S600 Front and Rear Casing Replacement
你所需要的
  1. Nikon CoolPix S600 Front and Rear Casing Replacement, Front and Rear Casing: 步骤 1 中的图像 1,1
    • With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
  2. Nikon CoolPix S600 Front and Rear Casing Replacement: 步骤 2 中的图像 1,1
    • Remove the chrome side cover from the body of the camera.
  3. Nikon CoolPix S600 Front and Rear Casing Replacement: 步骤 3 中的图像 1,1
    • Remove the four 3.2 mm screws on the bottom of the camera.
  4. Nikon CoolPix S600 Front and Rear Casing Replacement: 步骤 4 中的图像 1,2 Nikon CoolPix S600 Front and Rear Casing Replacement: 步骤 4 中的图像 2,2
    • Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
    • Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
  5. Nikon CoolPix S600 Front and Rear Casing Replacement: 步骤 5 中的图像 1,2 Nikon CoolPix S600 Front and Rear Casing Replacement: 步骤 5 中的图像 2,2
    • Gently separate the back cover from the body of the camera.
    • The back casing will still be connected to the circuit board by a ribbon
  6. Nikon CoolPix S600 Front and Rear Casing Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • Use the tweezers to disconnect the ribbon from the circuit board.
  7. Nikon CoolPix S600 Front and Rear Casing Replacement: 步骤 7 中的图像 1,1
    • Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
  8. Nikon CoolPix S600 Front and Rear Casing Replacement: 步骤 8 中的图像 1,2 Nikon CoolPix S600 Front and Rear Casing Replacement: 步骤 8 中的图像 2,2
    • Gently separate the front cover from the body of the camera.
    • The front casing will still be connected to the circuit board by a few wires
  9. Nikon CoolPix S600 Front and Rear Casing Replacement: 步骤 9 中的图像 1,1
    • Remove the two 3.2 mm screws that hold the flash to the front cover.
  10. Nikon CoolPix S600 Front and Rear Casing Replacement: 步骤 10 中的图像 1,3 Nikon CoolPix S600 Front and Rear Casing Replacement: 步骤 10 中的图像 2,3 Nikon CoolPix S600 Front and Rear Casing Replacement: 步骤 10 中的图像 3,3
    • Use the Spudger to remove the copper colored light bulb clip.
    • Remove the front cover entierly from the camera body.
结论
团队
Cuesta, Team 1-6, Zipperian Fall 2011 Cuesta, Team 1-6, Zipperian Fall 2011 的会员
CUESTA-ZIPPERIAN-F11S1G6
2 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 1,300
