当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the wristlet by untying the strap.
Open the SD/Battery cover.
Remove the four screws adjacent to the SD/battery opening using a Phillips #00 screwdriver.
Remove the side paneling of the camera by prying it off with your hands.
Start on the wristlet side of the camera and use the #00 Phillips screwdriver to remove the two screws that hold the backplate in place.
Repeat the removal of the two screws on the other side of the camera.
Separate the back faceplate from the rest of the camera.
Press lightly on the outer surface of the plastic LCD screen cover in each corner.
The plastic LCD screen cover should pop out of the back plate.
取消:我没有完成这个指南。
2等其他人完成本指南。
与5其他贡献者
于03/11/13注册
87 声望
创作了3篇指南
徽章: 8
+ 5更多徽章
CLEM-BENSON-S13S12G5
4 名成员
创作了14篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 16
总计 409
