当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Pry the back panel away from the body of the camera, using the space you just opened up.
Be careful not to damage the ribbon cable on the opposite end of the camera.
A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
The center connector is detached by flipping the black latch up and away from the center of the camera.
The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
Pry the front casing away from the body of the camera.
Be careful not to damage the wires that attach the front panel to the motherboard.
Short the leads on the capacitor near the flash to avoid a nasty shock when separating the casing from the body.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
