跳转到主内容
Nikon COOLPIX S3600 SD Card Replacement
  1. Nikon COOLPIX S3600 SD Card Replacement, SD Card: 步骤 1 中的图像 1,2 Nikon COOLPIX S3600 SD Card Replacement, SD Card: 步骤 1 中的图像 2,2
    • Push latch downwards to open the battery hatch located on the bottom right.
    • Memory card is located above the battery compartment.
  2. Nikon COOLPIX S3600 SD Card Replacement: 步骤 2 中的图像 1,3 Nikon COOLPIX S3600 SD Card Replacement: 步骤 2 中的图像 2,3 Nikon COOLPIX S3600 SD Card Replacement: 步骤 2 中的图像 3,3
    • Push in the memory card until you can't push it in any more and release.
    • Memory card should be slightly popped up.
    • Now you can carefully remove the memory card.
结论
Lenisha Poirier
于03/16/15注册
101 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 38
总计 3,675
