跳转到主内容
Nikon COOLPIX P7700 Multi Selector Wheel Replacement
你所需要的
  1. Nikon COOLPIX P7700 Multi Selector Wheel Replacement, Back Casing: 步骤 1 中的图像 1,2 Nikon COOLPIX P7700 Multi Selector Wheel Replacement, Back Casing: 步骤 1 中的图像 2,2
    • Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
    • Remove the side panel.
  2. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: 步骤 2 中的图像 1,1
    • Open the touch screen, and remove the three 4.3 mm black screws inside using the Phillips #00 screwdriver.
  3. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: 步骤 3 中的图像 1,1
    • Remove the 4.3 mm black screw on top of the camera, right above where the screen folds out. Use the Phillips #00 screwdriver.
  4. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: 步骤 4 中的图像 1,1
    • Remove the two 4.3 mm black screws on the right side of the camera using the Phillips #00 screwdriver.
  5. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: 步骤 5 中的图像 1,1
    • Remove the 4.3 mm black screws on the bottom of the camera using the Phillips #00 screwdriver.
  6. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: 步骤 6 中的图像 1,2 Nikon COOLPIX P7700 Multi Selector Wheel Replacement: 步骤 6 中的图像 2,2
    • Begin separating the camera into two parts.
    • It is okay to remove the orange ribbon. This will be easily put back into place when re-assembling.
  7. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: 步骤 7 中的图像 1,1
    • Remove the back casing.
  8. Nikon COOLPIX P7700 Multi Selector Wheel Replacement, Multi Selector Wheel: 步骤 8 中的图像 1,1
    • Remove the four 4.3 mm screws located on the far right metal plate. Use the Phillips #00 screwdriver.
  9. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: 步骤 9 中的图像 1,2 Nikon COOLPIX P7700 Multi Selector Wheel Replacement: 步骤 9 中的图像 2,2
    • Remove and replace wheel.
结论
7等其他人完成本指南。
Dustin Wahl
于03/11/15注册
775 声望
创作了4篇指南
团队
Colorado Springs, Team 2-7, Panko Spring 2015 Colorado Springs, Team 2-7, Panko Spring 2015 的会员
UCCS-PANKO-S15S2G7
3 名成员
创作了10篇指南
8条评论
Step 9: I believe that the multi-selector wheel component is soldered, 3 wires just visible in the photo for step 8. This will surely add to the time taken and difficulty.
I have a problem with this component. Firstly it's almost impossible to obtain the replacement parts, but if I could this guide would be invaluable; pictures are worth a thousand words! Thanks.
basstrom - 回复
where can I get the item ( wheel ) ?
Best regards and thank you for the good explanation
fiteluetkehoff - 回复
Where i can find this wheel for replacement?
skromnjagaserj - 回复
See my comment above, for spray cleaning the wheel without any replacement. Unless your wheel is brokwn, you can try my suggestion. It works.
JY - 回复
Please see my comment on the "general" method of fixing the wheel (using fast-drying contact cleaner) without ANY component replacement or unscrewing. It works really well but you may have to do it 1-3 times until all the dirt inside the wheel mechanism is removed. I have managed to restore my P7700 (after "fixing" the erratic Control Wheel and the dis-obedient Play button). Since then I have used the same method to fix the control wheel on my Samsung EX-1 camera (the control wheel was replaced twice by Samsung but the problem came back after a year or so). The root cause is probably a weak control wheel design (maybe tiny metal springs rotating over a base-plate with printed circuits). Now I know how to save money and trouble (for any compact camera with a similar control wheel design).
JY - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 33
总计 4,538
