跳转到主内容
Nikon COOLPIX P7700 LCD Screen Display Replacement
你所需要的
  1. Nikon COOLPIX P7700 LCD Screen Display Replacement, LCD Screen Display: 步骤 1 中的图像 1,2 Nikon COOLPIX P7700 LCD Screen Display Replacement, LCD Screen Display: 步骤 1 中的图像 2,2
    • Push down and slide the lock of the battery compartment to the unlock position.
    • The battery door should pop open.
    • Remove the battery.
  2. Nikon COOLPIX P7700 LCD Screen Display Replacement: 步骤 2 中的图像 1,1
    • Open the camera LCD screen so it's away from the body of the camera.
  3. Nikon COOLPIX P7700 LCD Screen Display Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the 4.3 screw on both the top and bottom of the screen's casing.
  4. Nikon COOLPIX P7700 LCD Screen Display Replacement: 步骤 4 中的图像 1,2 Nikon COOLPIX P7700 LCD Screen Display Replacement: 步骤 4 中的图像 2,2
    • Place the camera lens-side down and twist the screen so that it is perpendicular to the camera.
    • Remove the 4.3 mm screw on the side of the casing using the Phillips #00 screwdriver.
    • Twist the screen in the other direction and remove the other 4.3 mm screw.
    • These screws are very brittle! Be careful not to strip the screws. If you find that one has become stripped, follow this guide.
  5. Nikon COOLPIX P7700 LCD Screen Display Replacement: 步骤 5 中的图像 1,1
    • Remove the case from the screen.
  6. Nikon COOLPIX P7700 LCD Screen Display Replacement: 步骤 6 中的图像 1,1
    • Replace the LCD display.
结论
3等其他人完成本指南。
Matthew Seidel
于03/11/15注册
154 声望
撰写一个指南
团队
Colorado Springs, Team 2-7, Panko Spring 2015 Colorado Springs, Team 2-7, Panko Spring 2015 的会员
UCCS-PANKO-S15S2G7
3 名成员
创作了10篇指南
1指南评论
Do NOT follow this guide. There are numerous details left out of step 6 and there’s no troubleshooting guide. Most importantly, there’s no warning that this kind of repair really isn’t meant to be done by laypeople and that it’s to be done at the user’s own risk. These instructions don’t equip someone for this delicate task that, if done wrongly, can waste a lot of time and damage the camera, as happened in my case.
Alan Green - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 29
总计 1,854
