跳转到主内容
Nikon COOLPIX P7700 Focusing Screen Replacement
你所需要的
  1. Nikon COOLPIX P7700 Focusing Screen Replacement, Back Casing: 步骤 1 中的图像 1,2 Nikon COOLPIX P7700 Focusing Screen Replacement, Back Casing: 步骤 1 中的图像 2,2
    • Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
    • Remove the side panel.
  2. Nikon COOLPIX P7700 Focusing Screen Replacement: 步骤 2 中的图像 1,1
    • Open the touch screen, and remove the three 4.3 mm black screws inside using the Phillips #00 screwdriver.
  3. Nikon COOLPIX P7700 Focusing Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the 4.3 mm black screw on top of the camera, right above where the screen folds out. Use the Phillips #00 screwdriver.
  4. Nikon COOLPIX P7700 Focusing Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the two 4.3 mm black screws on the right side of the camera using the Phillips #00 screwdriver.
  5. Nikon COOLPIX P7700 Focusing Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the 4.3 mm black screws on the bottom of the camera using the Phillips #00 screwdriver.
  6. Nikon COOLPIX P7700 Focusing Screen Replacement: 步骤 6 中的图像 1,2 Nikon COOLPIX P7700 Focusing Screen Replacement: 步骤 6 中的图像 2,2
    • Begin separating the camera into two parts.
    • It is okay to remove the orange ribbon. This will be easily put back into place when re-assembling.
  7. Nikon COOLPIX P7700 Focusing Screen Replacement: 步骤 7 中的图像 1,1
    • Remove the back casing.
  8. Nikon COOLPIX P7700 Focusing Screen Replacement, Focusing Screen: 步骤 8 中的图像 1,1
    • Once the back casing is off, locate the 4.3 mm silver screw near the top of the camera and remove it using the Phillips #00 screwdriver.
  9. Nikon COOLPIX P7700 Focusing Screen Replacement: 步骤 9 中的图像 1,1
    • Remove the metal sheet from the camera.
    • It is okay to remove the orange ribbon from the camera.
  10. Nikon COOLPIX P7700 Focusing Screen Replacement: 步骤 10 中的图像 1,3 Nikon COOLPIX P7700 Focusing Screen Replacement: 步骤 10 中的图像 2,3 Nikon COOLPIX P7700 Focusing Screen Replacement: 步骤 10 中的图像 3,3
    • Remove the four 4.3 mm silver screws located on the ends of the chip using the Phillips #00 screwdriver.
  11. Nikon COOLPIX P7700 Focusing Screen Replacement: 步骤 11 中的图像 1,2 Nikon COOLPIX P7700 Focusing Screen Replacement: 步骤 11 中的图像 2,2
    • Remove the two 4.3 mm silver screws on the far right side of the camera using the Phillips #00 screwdriver.
  12. Nikon COOLPIX P7700 Focusing Screen Replacement: 步骤 12 中的图像 1,2 Nikon COOLPIX P7700 Focusing Screen Replacement: 步骤 12 中的图像 2,2
    • Lift and detach connector from board as shown.
  13. Nikon COOLPIX P7700 Focusing Screen Replacement: 步骤 13 中的图像 1,1
    • Remove the board from the camera to locate lens opening
  14. Nikon COOLPIX P7700 Focusing Screen Replacement: 步骤 14 中的图像 1,1
    • Remove the 4.3 mm screws from the metal sheet using the Phillips #00 screwdriver.
  15. Nikon COOLPIX P7700 Focusing Screen Replacement: 步骤 15 中的图像 1,1
    • Lift the metal sheet up and out of the camera.
  16. Nikon COOLPIX P7700 Focusing Screen Replacement: 步骤 16 中的图像 1,1
    • Locate the reflective lens.
  17. Nikon COOLPIX P7700 Focusing Screen Replacement: 步骤 17 中的图像 1,1
    • Remove the lens from the camera.
结论
2等其他人完成本指南。
Dustin Wahl
于03/11/15注册
775 声望
创作了4篇指南
团队
Colorado Springs, Team 2-7, Panko Spring 2015 Colorado Springs, Team 2-7, Panko Spring 2015 的会员
UCCS-PANKO-S15S2G7
3 名成员
创作了10篇指南
2条评论
Hey I have a P7700 that shows a lens error and focusing doesn't work.
I took it apart and removed the focus motor and it seems that the focus lens moves as it should but when turning it on the picture will be blurry for a second until the lens error comes up.
What issue is fixed by replacing this focus lens?
Dominik Bessler - 回复
Hello.
Do you have a service procedure to fix the exposure dial in this camera?
Hugo - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 14
过去 30 天: 29
总计 1,783
