跳转到主内容
Nikon COOLPIX P500 Rear Case Replacement
你所需要的
  1. Nikon COOLPIX P500 Rear Case Replacement, Battery: 步骤 1 中的图像 1,2 Nikon COOLPIX P500 Rear Case Replacement, Battery: 步骤 1 中的图像 2,2
    • Electric shock is a huge risk if the battery is not removed while taking the camera apart.
    • Press down and forward on the battery cover latch.
    • Push the orange latch, in the direction of the arrow on it, to release the battery.
  2. Nikon COOLPIX P500 Rear Case Replacement, Rear Case: 步骤 2 中的图像 1,3 Nikon COOLPIX P500 Rear Case Replacement, Rear Case: 步骤 2 中的图像 2,3 Nikon COOLPIX P500 Rear Case Replacement, Rear Case: 步骤 2 中的图像 3,3
    • Remove the marked 3mm screws.
    • Separate the two parts of the body of the camera slightly.
    • Make sure not to pull too hard because there are connector ribbons.
    • Detach the connector ribbons before fully separating the camera into two pieces.
  3. Nikon COOLPIX P500 Rear Case Replacement: 步骤 3 中的图像 1,1
    • Remove the labeled 3mm screws using a PH00 screwdriver.
  4. Nikon COOLPIX P500 Rear Case Replacement: 步骤 4 中的图像 1,1
    • Remove the brown metal plate.
结论
Kevin Scott
于01/22/15注册
517 声望
创作了3篇指南
团队
Cal Poly, Team 19-10, Maness Winter 2015 Cal Poly, Team 19-10, Maness Winter 2015 的会员
CPSU-MANESS-W15S19G10
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 12
总计 1,042
