跳转到主内容
Nikon COOLPIX P500 Image Sensor Replacement
你所需要的
  1. Nikon COOLPIX P500 Image Sensor Replacement, Motherboard: 步骤 1 中的图像 1,3 Nikon COOLPIX P500 Image Sensor Replacement, Motherboard: 步骤 1 中的图像 2,3 Nikon COOLPIX P500 Image Sensor Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Remove all the marked screws using a PH00 screwdriver.
    • Remove the two 3mm screws on the grip.
    • Remove the two 4mm screws on the side opposite the grip.
    • Remove the three 4mm screws on the base of the camera.
    • Remove the four 3mm screws on the base of the camera.
  2. Nikon COOLPIX P500 Image Sensor Replacement, Removing hidden screws: 步骤 2 中的图像 1,2 Nikon COOLPIX P500 Image Sensor Replacement, Removing hidden screws: 步骤 2 中的图像 2,2
    • Open the flash module of the camera.
    • Remove the 2mm screw from the microphone metal grid using a PH00 screwdriver.
    • Remove the 4mm screw that was under the metal microphone grid using a PH00 screwdriver.
  3. Nikon COOLPIX P500 Image Sensor Replacement: 步骤 3 中的图像 1,2 Nikon COOLPIX P500 Image Sensor Replacement: 步骤 3 中的图像 2,2
    • Separate the two parts of the body of the camera slightly.
    • Release the two cables by lifting up their respective clips with a spudger.
    • Make sure not to pull too hard because there are connector ribbons.
    • Detach the connector ribbons before fully separating the camera into two pieces.
    • These pictures were taken after the connector ribbons were released and the camera was separated into two parts. You will need to release the connector ribbons while the camera is still in one piece before you can separate it like the pictures.
  4. Nikon COOLPIX P500 Image Sensor Replacement: 步骤 4 中的图像 1,1
    • Use a spudger to flip up the cable lock in order to release the ribbon.
  5. Nikon COOLPIX P500 Image Sensor Replacement: 步骤 5 中的图像 1,2 Nikon COOLPIX P500 Image Sensor Replacement: 步骤 5 中的图像 2,2
    • Use a PH00 screwdriver to unscrew the four labeled 3mm metal screws on the metal backing.
    • Remove the four labeled 4mm screws connected to the motherboard.
    • Remove the metal support.
  6. Nikon COOLPIX P500 Image Sensor Replacement: 步骤 6 中的图像 1,2 Nikon COOLPIX P500 Image Sensor Replacement: 步骤 6 中的图像 2,2
    • Desolder the labeled soldering points.
    • Soldering irons are very hot. They can damage your device and inflict physical harm if proper care is not taken.
  7. Nikon COOLPIX P500 Image Sensor Replacement: 步骤 7 中的图像 1,2 Nikon COOLPIX P500 Image Sensor Replacement: 步骤 7 中的图像 2,2
  8. Nikon COOLPIX P500 Image Sensor Replacement: 步骤 8 中的图像 1,3 Nikon COOLPIX P500 Image Sensor Replacement: 步骤 8 中的图像 2,3 Nikon COOLPIX P500 Image Sensor Replacement: 步骤 8 中的图像 3,3
    • Use a spudger to unlock the labeled connector ribbons.
    • Disconnect the labeled connector ribbons.
  9. Nikon COOLPIX P500 Image Sensor Replacement: 步骤 9 中的图像 1,2 Nikon COOLPIX P500 Image Sensor Replacement: 步骤 9 中的图像 2,2
    • Use a spudger to unlock the two connector ribbons.
    • Disconnect the two connector ribbons.
  10. Nikon COOLPIX P500 Image Sensor Replacement: 步骤 10 中的图像 1,1
    • Remove the mother board from the camera.
  11. Nikon COOLPIX P500 Image Sensor Replacement, Image Sensor: 步骤 11 中的图像 1,1
    • Use a PH00 screwdriver to remove the two 2mm metal screws from the image sensor cover.
  12. Nikon COOLPIX P500 Image Sensor Replacement: 步骤 12 中的图像 1,1
    • Use a spudger to unlock the connector ribbon.
  13. Nikon COOLPIX P500 Image Sensor Replacement: 步骤 13 中的图像 1,1
    • Use a PH00 screwdriver to remove the three 3mm screws holding the image sensor down.
  14. Nikon COOLPIX P500 Image Sensor Replacement: 步骤 14 中的图像 1,1
    • Remove the image sensor.
结论
3等其他人完成本指南。
Kevin Scott
于01/22/15注册
517 声望
创作了3篇指南
团队
Cal Poly, Team 19-10, Maness Winter 2015 Cal Poly, Team 19-10, Maness Winter 2015 的会员
CPSU-MANESS-W15S19G10
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 1,912
