跳转到主内容
Nikon COOLPIX P500 Front Case Replacement
你所需要的
  1. Nikon COOLPIX P500 Front Case Replacement, Battery: 步骤 1 中的图像 1,2 Nikon COOLPIX P500 Front Case Replacement, Battery: 步骤 1 中的图像 2,2
    • Electric shock is a huge risk if the battery is not removed while taking the camera apart.
    • Press down and forward on the battery cover latch.
    • Push the orange latch, in the direction of the arrow on it, to release the battery.
  2. Nikon COOLPIX P500 Front Case Replacement, Motherboard: 步骤 2 中的图像 1,3 Nikon COOLPIX P500 Front Case Replacement, Motherboard: 步骤 2 中的图像 2,3 Nikon COOLPIX P500 Front Case Replacement, Motherboard: 步骤 2 中的图像 3,3
    • Remove all the marked screws using a PH00 screwdriver.
    • Remove the two 3mm screws on the grip.
    • Remove the two 4mm screws on the side opposite the grip.
    • Remove the three 4mm screws on the base of the camera.
    • Remove the four 3mm screws on the base of the camera.
  3. Nikon COOLPIX P500 Front Case Replacement, Removing hidden screws: 步骤 3 中的图像 1,2 Nikon COOLPIX P500 Front Case Replacement, Removing hidden screws: 步骤 3 中的图像 2,2
    • Open the flash module of the camera.
    • Remove the 2mm screw from the microphone metal grid using a PH00 screwdriver.
    • Remove the 4mm screw that was under the metal microphone grid using a PH00 screwdriver.
  4. Nikon COOLPIX P500 Front Case Replacement: 步骤 4 中的图像 1,2 Nikon COOLPIX P500 Front Case Replacement: 步骤 4 中的图像 2,2
    • Separate the two parts of the body of the camera slightly.
    • Release the two cables by lifting up their respective clips with a spudger.
    • Make sure not to pull too hard because there are connector ribbons.
    • Detach the connector ribbons before fully separating the camera into two pieces.
    • These pictures were taken after the connector ribbons were released and the camera was separated into two parts. You will need to release the connector ribbons while the camera is still in one piece before you can separate it like the pictures.
  5. Nikon COOLPIX P500 Front Case Replacement: 步骤 5 中的图像 1,1
    • Use a spudger to flip up the cable lock in order to release the ribbon.
  6. Nikon COOLPIX P500 Front Case Replacement: 步骤 6 中的图像 1,2 Nikon COOLPIX P500 Front Case Replacement: 步骤 6 中的图像 2,2
    • Use a PH00 screwdriver to unscrew the four labeled 3mm metal screws on the metal backing.
    • Remove the four labeled 4mm screws connected to the motherboard.
    • Remove the metal support.
  7. Nikon COOLPIX P500 Front Case Replacement: 步骤 7 中的图像 1,2 Nikon COOLPIX P500 Front Case Replacement: 步骤 7 中的图像 2,2
    • Desolder the labeled soldering points.
    • Soldering irons are very hot. They can damage your device and inflict physical harm if proper care is not taken.
  8. Nikon COOLPIX P500 Front Case Replacement: 步骤 8 中的图像 1,2 Nikon COOLPIX P500 Front Case Replacement: 步骤 8 中的图像 2,2
  9. Nikon COOLPIX P500 Front Case Replacement: 步骤 9 中的图像 1,3 Nikon COOLPIX P500 Front Case Replacement: 步骤 9 中的图像 2,3 Nikon COOLPIX P500 Front Case Replacement: 步骤 9 中的图像 3,3
    • Use a spudger to unlock the labeled connector ribbons.
    • Disconnect the labeled connector ribbons.
  10. Nikon COOLPIX P500 Front Case Replacement: 步骤 10 中的图像 1,2 Nikon COOLPIX P500 Front Case Replacement: 步骤 10 中的图像 2,2
    • Use a spudger to unlock the two connector ribbons.
    • Disconnect the two connector ribbons.
  11. Nikon COOLPIX P500 Front Case Replacement: 步骤 11 中的图像 1,1
    • Remove the mother board from the camera.
  12. Nikon COOLPIX P500 Front Case Replacement, Front Case: 步骤 12 中的图像 1,2 Nikon COOLPIX P500 Front Case Replacement, Front Case: 步骤 12 中的图像 2,2
    • Use a PH00 screwdriver to remove the three labeled 3mm screws.
  13. Nikon COOLPIX P500 Front Case Replacement: 步骤 13 中的图像 1,1
    • Remove the black plastic holding the image sensor from the camera. You now have access to the front casing of the camera.
结论
另外一个人完成了本指南。
Kevin Scott
于01/22/15注册
517 声望
创作了3篇指南
团队
Cal Poly, Team 19-10, Maness Winter 2015 Cal Poly, Team 19-10, Maness Winter 2015 的会员
CPSU-MANESS-W15S19G10
4 名成员
创作了14篇指南
一条评论
The manual is incomplete. There are several screws that need to be removed and are not mentioned in the manual. Also desolder the contacts to the battery, which are not mentioned in the manual ...
Juan Vivo - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 23
总计 2,510
