跳转到主内容
Nikon 1 AW 1 LCD Screen Replacement
你所需要的
  1. Nikon 1 AW 1 LCD Screen Replacement, Buttons: 步骤 1 中的图像 1,3 Nikon 1 AW 1 LCD Screen Replacement, Buttons: 步骤 1 中的图像 2,3 Nikon 1 AW 1 LCD Screen Replacement, Buttons: 步骤 1 中的图像 3,3
    • Using the Phillips PH00 screwdriver, remove the six 4.0mm screws marked in red. Then remove the panel cover by lightly pulling it off.
  2. Nikon 1 AW 1 LCD Screen Replacement: 步骤 2 中的图像 1,3 Nikon 1 AW 1 LCD Screen Replacement: 步骤 2 中的图像 2,3 Nikon 1 AW 1 LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Using the Phillips PH00 screwdriver, remove the four 5.5mm screws in the red circles. Then use a plastic opening tool to pry off the tripod socket.
    • Remove the metal plate to have access to the 4.9mm screw under the orange circle, use the Phillips PH00 screwdriver to remove it.
  3. Nikon 1 AW 1 LCD Screen Replacement: 步骤 3 中的图像 1,3 Nikon 1 AW 1 LCD Screen Replacement: 步骤 3 中的图像 2,3 Nikon 1 AW 1 LCD Screen Replacement: 步骤 3 中的图像 3,3
    • Using a T4 head screwdriver remove the three 5.4mm screws marked with the red circles.
    • Use a 1/4" flathead screwdriver or a flat head tool to release the grip attachment screw.
    • Remove the camera strap eyelet.
  4. Nikon 1 AW 1 LCD Screen Replacement: 步骤 4 中的图像 1,3 Nikon 1 AW 1 LCD Screen Replacement: 步骤 4 中的图像 2,3 Nikon 1 AW 1 LCD Screen Replacement: 步骤 4 中的图像 3,3
    • Remove the grip attachment screw.
    • Use a Phillips PH00 to remove the two 2.4mm screws on the grip attachment slot, then remove the slot.
  5. Nikon 1 AW 1 LCD Screen Replacement: 步骤 5 中的图像 1,3 Nikon 1 AW 1 LCD Screen Replacement: 步骤 5 中的图像 2,3 Nikon 1 AW 1 LCD Screen Replacement: 步骤 5 中的图像 3,3
    • Use a T4 screwdriver to remove the three 5.4mm screw marked with the red circles and the eyelet strap.
    • Use a plastic opening tool to lift the front camera cover off.
  6. Nikon 1 AW 1 LCD Screen Replacement: 步骤 6 中的图像 1,3 Nikon 1 AW 1 LCD Screen Replacement: 步骤 6 中的图像 2,3 Nikon 1 AW 1 LCD Screen Replacement: 步骤 6 中的图像 3,3
    • Use a Phillips PH00 to unscrew the two 3.5mm screws in red.
    • Press the flash pop-up button in the orange rectangle to be able to remove top cover of the camera.
  7. Nikon 1 AW 1 LCD Screen Replacement: 步骤 7 中的图像 1,3 Nikon 1 AW 1 LCD Screen Replacement: 步骤 7 中的图像 2,3 Nikon 1 AW 1 LCD Screen Replacement: 步骤 7 中的图像 3,3
    • Use a plastic opening tool to lift off the top panel.
  8. Nikon 1 AW 1 LCD Screen Replacement: 步骤 8 中的图像 1,1
    • If you needed to replace any buttons, you may now do so by pulling them off.
  9. Nikon 1 AW 1 LCD Screen Replacement, Internal Body Seal: 步骤 9 中的图像 1,3 Nikon 1 AW 1 LCD Screen Replacement, Internal Body Seal: 步骤 9 中的图像 2,3 Nikon 1 AW 1 LCD Screen Replacement, Internal Body Seal: 步骤 9 中的图像 3,3
    • Use a Phillips PH00 screwdriver to remove the 3.8mm screw in red.
    • Use a Phillips PH00 screwdriver to remove the 4.9mm screw in orange.
    • Use a Torx T4 screwdriver to remove the four 5.5mm screws in yellow.
  10. Nikon 1 AW 1 LCD Screen Replacement: 步骤 10 中的图像 1,3 Nikon 1 AW 1 LCD Screen Replacement: 步骤 10 中的图像 2,3 Nikon 1 AW 1 LCD Screen Replacement: 步骤 10 中的图像 3,3
    • Separate rear panel from the camera main body, starting from the HDMI and USB connector side. Do NOT pull the rear panel completely off of the camera yet.
    • Use a plastic opening tool to pry out the connector marked in red.
  11. Nikon 1 AW 1 LCD Screen Replacement: 步骤 11 中的图像 1,2 Nikon 1 AW 1 LCD Screen Replacement: 步骤 11 中的图像 2,2
    • Use the plastic opening tool to pull out the old seal from the groove in the rear panel.
    • If you needed to replace the seal, you may now do so.
  12. Nikon 1 AW 1 LCD Screen Replacement, Rear Panel: 步骤 12 中的图像 1,3 Nikon 1 AW 1 LCD Screen Replacement, Rear Panel: 步骤 12 中的图像 2,3 Nikon 1 AW 1 LCD Screen Replacement, Rear Panel: 步骤 12 中的图像 3,3
    • Use a Phillips PH00 screwdriver to remove the seven 3.1mm screws marked in red.
    • Use a Phillips PH00 screwdriver to remove the two 3.6mm screws marked in orange.
    • Lift off the small plate as shown.
  13. Nikon 1 AW 1 LCD Screen Replacement: 步骤 13 中的图像 1,3 Nikon 1 AW 1 LCD Screen Replacement: 步骤 13 中的图像 2,3 Nikon 1 AW 1 LCD Screen Replacement: 步骤 13 中的图像 3,3
    • Lift the rainbow cable to have access to the 3.1mm screw beneath it and unscrew it with a Phillips PH00 screwdriver.
    • Turn aside the LCD screen but do not completely remove it yet.
    • You will need to lift the sticky patch inside the the yellow rectangle, to access the 3.1mm screw marked in orange, remove it with Phillips PH00 screwdriver, then you will be able to separate the LCD screen from the rear panel.
  14. Nikon 1 AW 1 LCD Screen Replacement: 步骤 14 中的图像 1,3 Nikon 1 AW 1 LCD Screen Replacement: 步骤 14 中的图像 2,3 Nikon 1 AW 1 LCD Screen Replacement: 步骤 14 中的图像 3,3
    • Remove the back panel apart from LCD screen.
结论
3等其他人完成本指南。
Daniel Heshmaty
于10/04/16注册
397 声望
创作了3篇指南
团队
USF Tampa, Team 3-4, Sullivan Fall 2016 USF Tampa, Team 3-4, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S3G4
4 名成员
创作了6篇指南
1指南评论
Great thanks! Where can I order the screen?
terrykosick - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 17
总计 975
