本指南有最近更改,您可查看未经巡查的最新版本。
简介
Sometimes the only thing wrong with your camera is a broken button that won't let you turn it on. This guide will show you how to replace those problematic buttons.
你所需要的
Using the Phillips PH00 screwdriver, remove the six 4.0mm screws marked in red. Then remove the panel cover by lightly pulling it off.
另外一个人完成了本指南。
一条评论
What if the flash button is not working? How will i open or fix it? Flash does not pop out
