跳转到主内容
Nike SportWatch GPS LCD Screen Replacement
你所需要的
  1. Nike SportWatch GPS LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • First, place the watch upside down so the back of the watch is exposed. Unscrew the six size #000 5 mm long screws located on the back panel using a size 000 Phillips head screwdriver.
  2. Nike SportWatch GPS LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Carefully separate the watch by pulling the band away from the main board.
  3. Nike SportWatch GPS LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Then, unscrew the two main board size #000 2.5 mm long screws using a size 000 Phillips head screwdriver.
  4. Nike SportWatch GPS LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Carefully use the blue plastic opening tool to pry the main board out of the front panel.
    • Make sure to be gentle so the ribbon cable that connects to the band does not break, it is fragile and is not removable.
  5. Nike SportWatch GPS LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Use the blue plastic removal tool once again to carefully remove the screen.
  6. Nike SportWatch GPS LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Pull the plastic piece that is highlighted in the picture out from the back of the screen.
  7. Nike SportWatch GPS LCD Screen Replacement: 步骤 7 中的图像 1,1
    • For reassembly, make sure the highlighted area in the picture, goes over the black plastic piece that was removed in the previous step.
结论
3等其他人完成本指南。
Zainab Hussein
于10/27/15注册
222 声望
撰写一个指南
团队
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 的会员
UMASSD-GULBRANDSEN-F15S5G8
3 名成员
创作了5篇指南
3条评论
Hello, I found your article very interesting, I was just wondering do you know where I can buy a replacement screen?
Thank you
Joseph Kermani - 回复
hello do you know where I can find a replacement screen ?
Thank you
SMOUN - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 3,436
