跳转到主内容
Nike SportWatch GPS Front Panel Replacement
你所需要的
  1. Nike SportWatch GPS Front Panel Replacement, Front Panel: 步骤 1 中的图像 1,1
    • Face the watch upside down so that the back of the watch is exposed. Unscrew the six size #000 5 mm long screws on the back using a size 000 Phillips head screwdriver.
  2. Nike SportWatch GPS Front Panel Replacement: 步骤 2 中的图像 1,1
    • Carefully separate the watch by pulling the band away from the main board.
  3. Nike SportWatch GPS Front Panel Replacement: 步骤 3 中的图像 1,1
    • Two size #000 2.5 mm long screws will appear at the top of the main board. Unscrew them using a size 000 Phillips head screwdriver.
  4. Nike SportWatch GPS Front Panel Replacement: 步骤 4 中的图像 1,1
    • Carefully use the blue plastic opening tool to pry the main board out of the front panel.
    • Make sure to be gentle so the ribbon cable that connects to the band does not break, it is fragile and not removable.
  5. Nike SportWatch GPS Front Panel Replacement: 步骤 5 中的图像 1,1
    • Use an iOpener that has been heated in the microwave for about a minute, or until warm. Place it on the front screen of the watch. Let it rest there for a minute.
    • If you are unfamiliar with this tool use the iOpener guide here
  6. Nike SportWatch GPS Front Panel Replacement: 步骤 6 中的图像 1,1
    • Push the panel out from the back of the screen, using your fingers.
结论
Ian Eichorn
于10/22/15注册
678 声望
创作了4篇指南
团队
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 的会员
UMASSD-GULBRANDSEN-F15S5G8
3 名成员
创作了5篇指南
一条评论
Where I can find the replacement glass? regards
Erick Sobreiro - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 1,261
