跳转到主内容
Nike+ Sportband Motherboard Replacement
你所需要的
  1. Nike+ Sportband Motherboard Replacement, External Case: 步骤 1 中的图像 1,2 Nike+ Sportband Motherboard Replacement, External Case: 步骤 1 中的图像 2,2
    • To begin the disassembly of your NikePlus Sportband, first remove the device from the rubber wristband.
  2. Nike+ Sportband Motherboard Replacement: 步骤 2 中的图像 1,2 Nike+ Sportband Motherboard Replacement: 步骤 2 中的图像 2,2
    • Finish the disassembly of your NikePlus Sportband by utilizing the metal spudger tool on the short edge to pry the external body pieces apart.
  3. Nike+ Sportband Motherboard Replacement, Screen: 步骤 3 中的图像 1,2 Nike+ Sportband Motherboard Replacement, Screen: 步骤 3 中的图像 2,2
    • After the cover had been removed, use the metal spudger tool to remove the body of the device from the casing.
  4. Nike+ Sportband Motherboard Replacement: 步骤 4 中的图像 1,3 Nike+ Sportband Motherboard Replacement: 步骤 4 中的图像 2,3 Nike+ Sportband Motherboard Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use the metal tweezers to pry the screen casing from the body of the device.
    • The screen casing is fastened to the body of the device by four clips located in each corner of the casing.
  5. Nike+ Sportband Motherboard Replacement: 步骤 5 中的图像 1,2 Nike+ Sportband Motherboard Replacement: 步骤 5 中的图像 2,2
    • Flip the body of the device over so that the screen is now on the bottom.
    • The display ribbon cable is soldered to the motherboard. We were able to peel up the ribbon cable with a pair of tweezers.
    • Successfully resoldering this ribbon cable to the motherboard may prove difficult to the very small traces.
  6. Nike+ Sportband Motherboard Replacement: 步骤 6 中的图像 1,3 Nike+ Sportband Motherboard Replacement: 步骤 6 中的图像 2,3 Nike+ Sportband Motherboard Replacement: 步骤 6 中的图像 3,3
    • Flip the body of the device back over so that the screen is facing up.
    • Using the tweezers, gently lift the screen from body of the device.
  7. Nike+ Sportband Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,1
    • Remove the four highlighted screws from the motherboard using the Philips screwdriver.
  8. Nike+ Sportband Motherboard Replacement: 步骤 8 中的图像 1,3 Nike+ Sportband Motherboard Replacement: 步骤 8 中的图像 2,3 Nike+ Sportband Motherboard Replacement: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use the metal tweezers to lift the motherboard out of the device.
结论
Alyssa Setnar
于02/15/16注册
331 声望
创作了3篇指南
团队
IUPUI, Team 9-9, Wilson Spring 2016 IUPUI, Team 9-9, Wilson Spring 2016 的会员
IUPUI-WILSON-S16S9G9
5 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 249
