跳转到主内容
Nexus S SIM Card Replacement
你所需要的
  1. Nexus S SIM Card Replacement, Rear Panel: 步骤 1 中的图像 1,1
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
  2. Nexus S SIM Card Replacement: 步骤 2 中的图像 1,1
    • Remove the rear panel from the Nexus S.
  3. Nexus S SIM Card Replacement, Battery: 步骤 3 中的图像 1,1
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
  4. Nexus S SIM Card Replacement, SIM Card: 步骤 4 中的图像 1,2 Nexus S SIM Card Replacement, SIM Card: 步骤 4 中的图像 2,2
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
结论
7等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 6
过去 30 天: 21
总计 7,588
