跳转到主内容
Nexus S Rear Inner Frame Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Nexus S Rear Inner Frame Replacement, Rear Inner Frame: 步骤 1 中的图像 1,1
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
  2. Nexus S Rear Inner Frame Replacement: 步骤 2 中的图像 1,1
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
  3. Nexus S Rear Inner Frame Replacement: 步骤 3 中的图像 1,2 Nexus S Rear Inner Frame Replacement: 步骤 3 中的图像 2,2
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  4. Nexus S Rear Inner Frame Replacement: 步骤 4 中的图像 1,2 Nexus S Rear Inner Frame Replacement: 步骤 4 中的图像 2,2
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  5. Nexus S Rear Inner Frame Replacement: 步骤 5 中的图像 1,1
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  6. Nexus S Rear Inner Frame Replacement: 步骤 6 中的图像 1,1
    • Lift and remove the rear inner frame from the Nexus S.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 294
