简介
Use this guide to replace the motherboard (includes rear camera and speaker).
你所需要的
Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
Remove the battery from the Nexus S.
Use your thumb to slide the SIM card downwards from the SIM card slot.
Remove the SIM card.
Remove the six Phillips screws securing the rear inner frame to the inner case.
Disconnect the following cables from their respective sockets on the motherboard:
Headphone jack cable
Digitizer cable connector
Camera/SIM board connector
15等其他人完成本指南。
