跳转到主内容
Nexus Q NFC Antenna Replacement
你所需要的
  1. Nexus Q NFC Antenna Replacement, Taoglas PU18 Wi-Fi Dual Band Antenna: 步骤 1 中的图像 1,1
    • Squeeze and pull to pop the cap off of the Nexus Q.
  2. Nexus Q NFC Antenna Replacement: 步骤 2 中的图像 1,2 Nexus Q NFC Antenna Replacement: 步骤 2 中的图像 2,2
    • Disconnect the taoglas Wi-Fi Dual Band Antenna by prying with a spudger.
    • Once the antenna is disconnected, simply pull it off the outside of the inner dome.
  3. Nexus Q NFC Antenna Replacement, Inner Dome Daughterboard: 步骤 3 中的图像 1,1
    • Undo the ZIF connector by prying with a spudger.
  4. Nexus Q NFC Antenna Replacement: 步骤 4 中的图像 1,1
    • Use a T10 Torx screwdriver to remove the four 1.3 mm screws holding the inner dome in place.
  5. Nexus Q NFC Antenna Replacement: 步骤 5 中的图像 1,1
    • Use a T6 Torx screwdriver to undo the three 0.8 mm screws holding the inner dome daughterboard in place.
  6. Nexus Q NFC Antenna Replacement: 步骤 6 中的图像 1,1
    • Use a spudger to disconnect the daughterboard from the ZIF connector.
  7. Nexus Q NFC Antenna Replacement, NFC Antenna: 步骤 7 中的图像 1,2 Nexus Q NFC Antenna Replacement, NFC Antenna: 步骤 7 中的图像 2,2
    • Use a spudger to pry out the NFC antenna.
    • The antenna has two layers; be careful not to pry the two layers apart.
结论
另外一个人完成了本指南。
Alex Thomas
于01/31/13注册
27 声望
创作了3篇指南
团队
Cal Poly, Team 7-10, Maness Winter 2013 Cal Poly, Team 7-10, Maness Winter 2013 的会员
CPSU-MANESS-W13S7G10
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 633
