跳转到主内容
Nexus Q LED Board Replacement
你所需要的
  1. Nexus Q LED Board Replacement, Ball Bearing Ring: 步骤 1 中的图像 1,1
    • Squeeze and pull the cap to remove it from the Nexus Q.
  2. Nexus Q LED Board Replacement: 步骤 2 中的图像 1,1
    • Use a spudger to disconnect the Taoglas Wi-Fi Dual Band Antenna.
  3. Nexus Q LED Board Replacement: 步骤 3 中的图像 1,1
    • Undo the ZIF connector by prying it with a spudger.
  4. Nexus Q LED Board Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #0 screwdriver to unscrew the four 1.3 mm screws.
    • After removing the screws, there will be two parts. The top part contains the daughterboard. Store it safely. It will not be used.
  5. Nexus Q LED Board Replacement: 步骤 5 中的图像 1,1
    • View the bottom half of the Nexus Q.
    • Use a Phillips #0 screwdriver to remove the four 0.8 mm screws holding the ball bearing ring in place.
  6. Nexus Q LED Board Replacement: 步骤 6 中的图像 1,1
    • Remove the ball bearing ring.
    • When placing a new ring in its place, make sure to orient it right or the top will not close.
  7. Nexus Q LED Board Replacement, LED Board: 步骤 7 中的图像 1,2 Nexus Q LED Board Replacement, LED Board: 步骤 7 中的图像 2,2
    • Once you remove the ball bearing ring from the bottom half of the Nexus Q, you will be exposed to a diffuser (white ring) held in with three T6 Torx screws.
    • Use a #0 Philips head screwdriver to remove the three 0.8 mm screws holding the diffuser in place.
  8. Nexus Q LED Board Replacement: 步骤 8 中的图像 1,2 Nexus Q LED Board Replacement: 步骤 8 中的图像 2,2
    • With the diffuser out, we are exposed to the LED Board.
    • Use a spudger to lightly lift the LED board out.
结论
Taewan Kim
于01/31/13注册
22 声望
创作了2篇指南
团队
Cal Poly, Team 7-10, Maness Winter 2013 Cal Poly, Team 7-10, Maness Winter 2013 的会员
CPSU-MANESS-W13S7G10
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 584
