跳转到主内容
加入维修社区 - 创建账户
Nexus One Vibrator Replacement
你所需要的
  1. Nexus One Vibrator Replacement, Lower Cover: 步骤 1 中的图像 1,2 Nexus One Vibrator Replacement, Lower Cover: 步骤 1 中的图像 2,2
    • Using the plastic opening tool, push the blade into the space between the case and lower cover.
    • Turn the opening tool slightly, the lower cover will detach on that side.
    • Repeat on other side of the seam.
    • The lower cover will slide off.
  2. Nexus One Vibrator Replacement, Antenna Housing: 步骤 2 中的图像 1,1
    • Remove the one T5 Torx screw
    • Remove the one #00 Philips screw
    • Lift up the end of the antenna housing and slide it outwards.
    • The vibrator is located on the back of the antenna housing.
    • Use the spudger to pry up on the axle of the motor.
结论
Niklas Johnson
于01/31/12注册
1,207 声望
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 19
总计 1,722
