跳转到主内容
Nexus One Upper Motherboard Replacement
你所需要的
  1. Nexus One Upper Motherboard Replacement, Rear Cover: 步骤 1 中的图像 1,2 Nexus One Upper Motherboard Replacement, Rear Cover: 步骤 1 中的图像 2,2
    • Using two fingers, push up on the rear cover.
  2. Nexus One Upper Motherboard Replacement: 步骤 2 中的图像 1,1
    • The rear cover slides up and off.
  3. Nexus One Upper Motherboard Replacement, Battery: 步骤 3 中的图像 1,1
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Nexus One Upper Motherboard Replacement: 步骤 4 中的图像 1,1
    • Pull the battery up and out.
  5. Nexus One Upper Motherboard Replacement, Battery Housing: 步骤 5 中的图像 1,1
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  6. Nexus One Upper Motherboard Replacement: 步骤 6 中的图像 1,2 Nexus One Upper Motherboard Replacement: 步骤 6 中的图像 2,2
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  7. Nexus One Upper Motherboard Replacement: 步骤 7 中的图像 1,2 Nexus One Upper Motherboard Replacement: 步骤 7 中的图像 2,2
    • Pry the upper left tab open on the battery housing.
  8. Nexus One Upper Motherboard Replacement: 步骤 8 中的图像 1,2 Nexus One Upper Motherboard Replacement: 步骤 8 中的图像 2,2
    • Pry the top tab of the battery housing.
  9. Nexus One Upper Motherboard Replacement: 步骤 9 中的图像 1,2 Nexus One Upper Motherboard Replacement: 步骤 9 中的图像 2,2
    • Pry the right side tab of the battery housing.
  10. Nexus One Upper Motherboard Replacement: 步骤 10 中的图像 1,2 Nexus One Upper Motherboard Replacement: 步骤 10 中的图像 2,2
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  11. Nexus One Upper Motherboard Replacement, Lower Cover: 步骤 11 中的图像 1,2 Nexus One Upper Motherboard Replacement, Lower Cover: 步骤 11 中的图像 2,2
    • Using the plastic opening tool, push the blade into the space between the case and lower cover.
    • Turn the opening tool slightly, the lower cover will detach on that side.
    • Repeat on other side of the seam.
    • The lower cover will slide off.
  12. Nexus One Upper Motherboard Replacement, Antenna Housing: 步骤 12 中的图像 1,1
    • Remove the one T5 Torx screw
    • Remove the one #00 Philips screw
    • Lift up the end of the antenna housing and slide it outwards.
  13. Nexus One Upper Motherboard Replacement, Secondary Microphone: 步骤 13 中的图像 1,2 Nexus One Upper Motherboard Replacement, Secondary Microphone: 步骤 13 中的图像 2,2
    • Using the spudger, pry upwards on the second microphone connector.
  14. Nexus One Upper Motherboard Replacement: 步骤 14 中的图像 1,1
    • Pull up on the ribbon cable, the tape will detach from the main board ribbon.
  15. Nexus One Upper Motherboard Replacement, Antenna Cable: 步骤 15 中的图像 1,2 Nexus One Upper Motherboard Replacement, Antenna Cable: 步骤 15 中的图像 2,2
    • Pry the antenna cable up.
  16. Nexus One Upper Motherboard Replacement: 步骤 16 中的图像 1,1
    • Carefully pull up on the microphone board to release the tape from the phone.
  17. Nexus One Upper Motherboard Replacement, Motherboards: 步骤 17 中的图像 1,2 Nexus One Upper Motherboard Replacement, Motherboards: 步骤 17 中的图像 2,2
    • Insert the spudger under the connector.
    • Push the spudger up and twist to release the connector.
    • Repeat for the next connector.
  18. Nexus One Upper Motherboard Replacement: 步骤 18 中的图像 1,3 Nexus One Upper Motherboard Replacement: 步骤 18 中的图像 2,3 Nexus One Upper Motherboard Replacement: 步骤 18 中的图像 3,3
    • Push on the USB port to expose the black connector.
    • Use the spudger to pry the connector upwards.
  19. Nexus One Upper Motherboard Replacement: 步骤 19 中的图像 1,2 Nexus One Upper Motherboard Replacement: 步骤 19 中的图像 2,2
    • Place the spugder under the antenna connector.
    • Pry connector up vertically.
  20. Nexus One Upper Motherboard Replacement: 步骤 20 中的图像 1,3 Nexus One Upper Motherboard Replacement: 步骤 20 中的图像 2,3 Nexus One Upper Motherboard Replacement: 步骤 20 中的图像 3,3
    • Insert the spudger into tab above the camera.
    • Slide upwards until the board detaches from the case.
  21. Nexus One Upper Motherboard Replacement: 步骤 21 中的图像 1,1
    • Press the pointed tip of the spudger into the space below the button assembly.
    • Wiggle the spudger tip towards the outside of the button.
    • The button assembly is under some tension and may fly off.
  22. Nexus One Upper Motherboard Replacement: 步骤 22 中的图像 1,1
    • Push the pointed tip of the spudger into the base of the side button board.
    • Lift up, the board will disconnect from the case.
  23. Nexus One Upper Motherboard Replacement: 步骤 23 中的图像 1,3 Nexus One Upper Motherboard Replacement: 步骤 23 中的图像 2,3 Nexus One Upper Motherboard Replacement: 步骤 23 中的图像 3,3
    • Push on the lower motherboard until it slides under the case support.
    • The motherboard assembly comes out as a single piece.
    • Save the small black rubber rectangular sound guide under the motherboard, to replace over the microphone.
  24. Nexus One Upper Motherboard Replacement, Upper Motherboard: 步骤 24 中的图像 1,2 Nexus One Upper Motherboard Replacement, Upper Motherboard: 步骤 24 中的图像 2,2
    • Using the spudger, lift the blue colored connector.
    • Use the supdger to lift the black connetor up as well.
    • Detach the upper motherboard from the lower motherboard.
结论
另外一个人完成了本指南。
Niklas Johnson
于01/31/12注册
1,207 声望
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 3,855
