跳转到主内容
Nexus One Rear Speaker Replacement
你所需要的
  1. Nexus One Rear Speaker Replacement, Rear Cover: 步骤 1 中的图像 1,2 Nexus One Rear Speaker Replacement, Rear Cover: 步骤 1 中的图像 2,2
    • Using two fingers, push up on the rear cover.
  2. Nexus One Rear Speaker Replacement: 步骤 2 中的图像 1,1
    • The rear cover slides up and off.
  3. Nexus One Rear Speaker Replacement, Battery: 步骤 3 中的图像 1,1
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Nexus One Rear Speaker Replacement: 步骤 4 中的图像 1,1
    • Pull the battery up and out.
  5. Nexus One Rear Speaker Replacement, Battery Housing: 步骤 5 中的图像 1,1
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  6. Nexus One Rear Speaker Replacement: 步骤 6 中的图像 1,2 Nexus One Rear Speaker Replacement: 步骤 6 中的图像 2,2
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  7. Nexus One Rear Speaker Replacement: 步骤 7 中的图像 1,2 Nexus One Rear Speaker Replacement: 步骤 7 中的图像 2,2
    • Pry the upper left tab open on the battery housing.
  8. Nexus One Rear Speaker Replacement: 步骤 8 中的图像 1,2 Nexus One Rear Speaker Replacement: 步骤 8 中的图像 2,2
    • Pry the top tab of the battery housing.
  9. Nexus One Rear Speaker Replacement: 步骤 9 中的图像 1,2 Nexus One Rear Speaker Replacement: 步骤 9 中的图像 2,2
    • Pry the right side tab of the battery housing.
  10. Nexus One Rear Speaker Replacement: 步骤 10 中的图像 1,2 Nexus One Rear Speaker Replacement: 步骤 10 中的图像 2,2
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  11. Nexus One Rear Speaker Replacement, Rear Speaker: 步骤 11 中的图像 1,1
    • Push up the speaker from the battery housing.
结论
Niklas Johnson
于01/31/12注册
1,207 声望
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,446
