简介
Replace the vibrator on your Nexus 9.
你所需要的
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
Disconnect the two ZIF connectors attached to the daughterboards.
Gently pull on the ribbon cable to remove it.
即将完成!
结论
